94+ lt1 heads on 79 chev 400??
Old Apr 14, 2008 | 10:24 PM
orangehauler's Avatar
Will 94+ lt1 heads fit a 79 chev 400 bored 40 over
Old Apr 15, 2008 | 01:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not without a bunch of work that would cost you as much or more than a set of Vortec heads, which would provide all of the benefits of the LT1 heads with none of the hassles.
Old Apr 15, 2008 | 06:44 AM
Re: 94+ lt1 heads on 79 chev 400??
i know the heads need to be converted but what blocks will the lt1 heads fit on once there converted
Old Apr 15, 2008 | 01:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are talking about the aluminum LT1 heads, even a converted set would be a poor choice... they have tiny little 53cc chambers, so it would be almost impossible to get a good set of pistons that will bring down the compression to a reasonable level on a 400.
The Vortec heads are a better choice - they are based on the LT1 heads (same chamber design, but 64cc) and they breathe better in stock form too. They will also bolt right on, with the only major change being the intake manifold. Dollars and power ahead using those over the LT1s.
The LT1 will physically bolt on to any Gen 1 small block once its been converted. Everything from the 262ci to 400ci and all in between.
Old Apr 15, 2008 | 11:03 PM
I have a complete intake for a lt1 will that fit on vortec heads if not whats other heads will it fit on
Old Apr 16, 2008 | 05:57 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The LT1 intake will fit on any standard SBC heads, but has to be modified to allow for the coolant passages in the head and a hole drilled in the back and spacers for the distributor. You would also have to run a remote thermostat housing since there is no place for the thermostat to go in the LT1 intake. You can do a search or goto http://www.lt1intake.com to see how the modification is done.
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
355tpipickup
Aug 25, 2015 12:54 AM
lakeffect2
Aug 23, 2015 08:44 AM
