any thoughts
Old Apr 23, 2008 | 09:10 PM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
any thoughts
Posted this in general but got no replies, hoping to get some thoughts
I'm putting this motor in place of 305 tbi. I hope to get on the road this summer.
Basic use will be little street, little strip, little sitting at cruise ins
Short block:385 cu
350 2 bolt arp studs .040,
Sealed power hv oil pump,
Moroso oil restrictors,
Renagade 3.75 steel crankshaft,
Eagle 5.7 h beam floating pins
Speed pro H635cp40 ..200 dome coated pistons aprox. 12.4:1cr w/ 64 cc heads
ballanced rotating assy,
Renagade +.100 pushrods
Lunati 40145 solid flat tappet cam
Int:.552 lift 256 dur@.050 .024 lash
Exh:.519 lift 259 dur @.050 .030 lash
106 lobe seperation
installed straight up aprox range per lunati 3800-7000rpm,
dual idler gear drive of unknown origin.
Heads:
GM cast iron BowTie 2.02 intake 1.6 exh unported,
Manley undercut valves,
K-motion tool steel springs good to .600,
3/8 ARP studs w/ guide plates,
Crane 1.5 silver rollers,
Pro products stud girdle,
Pro products#52031 power+plus single plane manifold,
Holley 750 vacume secondary(only carb I have other than 2bbl)
Tranny:
local built 700r4 w acc2200-2800 converter#48442(I know too low but I got it for free)
Rear:
10 bolt 3:73 limited slip(still need to set up)
The motor ran strong on a 3/8 dirt track in 75 nova(3200lbs) w/ cast iron dual plane BowTie intake, stamped longslot rockers and a Duel jet carb
What are your thoughts, and how much power do you think I'll make. Are there any other mods that I'll need
Old Apr 24, 2008 | 09:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What are you going to burn for fuel?
Old Apr 24, 2008 | 01:19 PM
Re: any thoughts
Track Tech 111 octane racing fuel(leaded)
Old Apr 24, 2008 | 01:51 PM
five7kid's Avatar
Ouch, that's gotta hurt the old pocketbook.
Ever consider E85? Not sure of availability in MO, but I would think it's better than some places.
The high CR is the only concern I would have for a cruiser.
Old Apr 24, 2008 | 05:58 PM
Re: any thoughts
I hadn't even thought about E 85. It's readily availible around here so it might be worth looking into. The track tech is only $5.69 a gallon right now in Holts Summit Mo.
Other than jetting, pump and hoses what else would I need for E 85 and what is the octane rating. Phillips/Conoco rep. said that I should stay above 104 octane with this set up.
Old Apr 24, 2008 | 06:26 PM
five7kid's Avatar
Typical for E85 is 105 octane. Interestingly enough, I've never seen an octane sticker on an E85 pump. I can get it for $2.65/gal at the track, $2.75 at a station if I drive a ways, and $3.09 at the closest station to my house. I take 2 5-gal gas cans to the track every time I go.
Pump - depends upon what you've got. If you're running an electric, make sure it's alcohol-compatible and provides a little more capacity than a similar HP gasoline pump.
Hoses - materials are compatible with ethanol these days.
Jetting - Make life easy on yourself and get the Quick Fuel Technologies E85 metering blocks. Follow their jetting recommendations. The PV & idle restrictors are up-sized, and the emulsion bleeds modified to make the carb respond to the fuel properly. You'll convert to 4150 in the process.
Elephantismo
Feb 13, 2019 12:51 AM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
