What flywheel?
Old Apr 27, 2008 | 08:25 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
What flywheel?
Alright so i was hoping that the flywheel off my L69 would fit the 350 im dropping in it, but they are different. I think the 350 is a 1 piece rear main seal, so what could I use for a flywheel? Any old one off a 1 piece rear main motor? Also would it be worth it to get a lightweight flywheel? Thanks
Old Apr 27, 2008 | 11:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: What flywheel?
Yes, you need one from a 305/350 with a 1pc rear seal, 153 tooth ring gear.
Old Apr 28, 2008 | 07:24 AM
brodysZ28's Avatar
Engine: 383
Re: What flywheel?
ok, do i need a different starter too? i have my 305 one and the one off the 350.
Old Apr 28, 2008 | 12:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'86-'92 f-body V8 flywheel. It'll be 153-tooth, just like your current 305, so same starter.
Old Apr 28, 2008 | 02:16 PM
brodysZ28's Avatar
Engine: 383
Re: What flywheel?
ok, thanks, is a lightweight flywheel worth the money?
Old Apr 28, 2008 | 06:41 PM
Air_Adam's Avatar
Re: What flywheel?
Probably not. I wouldn't worry about it.
Old Apr 28, 2008 | 07:14 PM
brodysZ28's Avatar
Engine: 383
Re: What flywheel?
ok, i will be able to use the same clutch right?
Old Apr 28, 2008 | 09:08 PM
Air_Adam's Avatar
Re: What flywheel?
Yes.
Old Apr 29, 2008 | 07:20 AM
brodysZ28's Avatar
Engine: 383
Re: What flywheel?
sweet, thanks guys, i ordered a 12.1 lb flywheel. does anybody know what the stock ones weigh?
Old Apr 29, 2008 | 12:32 PM
five7kid's Avatar
19, 20, something like that.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
