Small Block 400 in Third Gen
Old May 4, 2008 | 08:14 PM
Bad5OGT's Avatar
Car: 1986 Ford Mustang GT
Engine: 5.0
Okay, so I was considering throwing this 400 in my T/A as some of you may remember. The T/A has been sold to someone whom was in the market for restoring such a car, so that leaves me with the 400 and my '86 Z28.
My question basically remains the same, except for the small fact that my Z28 has a 5 speed, not a 700R4. Now my problem here being that I can not for the life of me find a 153 tooth flywheel for a 400. Atleast not one that doesn't cost less than $350!
Any one know where I can get one for fairly cheap? Any help and comments welcome. Thanks.
Old May 5, 2008 | 12:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You aren't going to find one cheap. You're talking about a non-production configuration, therefore specialty, therefore expensive.
You might be able to get a neutral balance 2-piece rear main seal 153 tooth flywheel and get a machine shop to unbalance it for you. That'll probably add up to less than $350 - like $349.95.
Old May 6, 2008 | 03:39 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
Re: Small Block 400 in Third Gen
have you measured a flywheel off of a 307?
Old May 6, 2008 | 04:42 PM
five7kid's Avatar
How exactly would that help? Most likely it would be 168-tooth, and it would be neutral balance.
Old May 6, 2008 | 06:10 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
why not run a 168 and buy a diff. starter?
Old May 6, 2008 | 06:43 PM
five7kid's Avatar
Won't fit in the T5 bellhousing.
Old May 6, 2008 | 08:24 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
doh missed that
Old May 7, 2008 | 07:29 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
i thought the 307 flywheel was smaller. my brother has a 307 laying around and its flexplate for an automatic is smaller than the one on my 350.
just a suggestion!
Old May 7, 2008 | 09:32 AM
five7kid's Avatar
Flexplate/flywheel size has nothing to do with the engine. Except for 400, any SBC could have either one. Depends more on the vehicle it's installed in than the engine itself.
But, T5's were all 153 tooth.
Old May 8, 2008 | 09:24 AM
chesterfield's Avatar
Car: Pontiac
Here:
http://www.speedwaymotors.com/p/3262...o=flywheel+383
Old May 11, 2008 | 10:39 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
A local driveline/clutch shop should be able to get you a balance plate that sandwiches between the flywheel and the crank and adds the proper balance weight.They cost around $50,I've used them without any problems.If you can't get one locally,PM me,and I'll get you the # at my local shop,they can ship you oneBTW,you sure you want that kind of torque on a T5?
Old May 20, 2008 | 02:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Centerforce makes one, at least they used to a few years back, when I had my 400SBC 83 'bird. I think it was around $400 though...
Edit, Found it:
http://store.summitracing.com/egnsea...=KeywordSearch
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
