305 to z383
Old Jun 8, 2008 | 11:56 PM
joes85camaro's Avatar
305 to z383
i have an 85 with a 305 engine in it can i swap to a z383 ???
Old Jun 9, 2008 | 01:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
Yes, you can. Externally the engines are dimensionally identical. But, as always, the devil is in the details. How much do you know about 383's, and the changes to small block Chevys over the years?
Old Jun 11, 2008 | 12:45 AM
Re: 305 to z383
not to well i was gona put a 350 in then i stumbled on to the z383 so i liked wat its potention held so iam intrested in the engine
Old Jun 11, 2008 | 09:18 AM
five7kid's Avatar
If you've identified a 383, then you need to know the details: what block was used, what type of crank (rear main seal type, specifically), internally or externally balanced (which isn't universally followed what exactly that means), roller or flat tappet lifters.
Old Jun 12, 2008 | 12:50 AM
Re: 305 to z383
will the wiring be the same or im i gona have to rewire some stuff cause im gona put an accel DFI 1200cfm or a 1000 i dnt remember will it be okay
Old Jun 12, 2008 | 02:14 AM
five7kid's Avatar
I'm sure you'll have to do some rewiring for the DFI. Let Accel help with that part.
Old Jun 13, 2008 | 12:49 AM
Re: 305 to z383
hey wat should my 85 camaro temp be cause its run like 220 and 230
Old Jun 18, 2008 | 09:08 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: 305 to z383
then it is running at the stock setting. if you look in the cooling sections of thirdgen.org you will find lots of way to make you car run cooler. you would have to do things like thermostat AND fan switch cause if you dont get the fans on sooner than the factory setting then a stat will get you nowhere.
Old Jun 18, 2008 | 04:20 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
Re: 305 to z383
Dont mean to hi-jack, but Im thinking about the same swap. A 383 from Blueprint (Jegs has them, and Ive searched for them here also). Ive tried searching, but Im comfused over what parts from my 305 I can reuse. I think I can reuse the:
Water pump
Flexplate (maybe)
accessory brackets for A/C, P/S, and the Alternator
motor mounts
and even the same hoses.
I know the fuel pump has to be changed as well as the pickup. And Ill need a distributer. But as stated above, the devil is in the details, and I dont know much about the details. Is there a post that includes everything thats reusable for the swap?
Old Jun 18, 2008 | 04:52 PM
five7kid's Avatar
There won't be one with all of the details because there are too many configuration possibilities from '82-'92.
I wouldn't reuse hoses - replace them.
Fuel pump pick-up shouldn't have to be changed.
Are you going carb, or sticking with TBI? I assume carb since you mentioned needing a different distributor. You will need a fuel pressure regulator if you use the in-tank electric pump, or modify the pick-up per the sticky on the Carburetor forum if you use mechanical or in-line electric.
Old Jun 18, 2008 | 05:16 PM
DrummerDad's Avatar
Transmission: auto
Re: 305 to z383
Yeah carbed, sorry.
So the accessories will all bolt up? And I assume the flexplate also, as long as the engine I replace mine with is a one piece seal, correct?
And I have a single fan. I assume Ill need a dual to keep the bigger engine cool, right? Do you guys buy after market, or just hit the junk yard for a factory dual fan set-up?
Ill stop with the stupid questions. I just need to know, so I know what Im looking at for a swap cost. And searching turns up alot of info, but I dont always find exactly what I need to know. Thanks.
Old Jun 18, 2008 | 06:04 PM
five7kid's Avatar
Single stock fan keeps mine cool just fine.
Old Jun 25, 2008 | 07:08 PM
Re: 305 to z383
um the 383 im getting has been dynoed at 500 hp and the intake i want is for over 500 will it conflict cause im in the middle of the accel dfi 750 cfm and the 1200 cfm
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
