I swap V6 to V8 L05 and upgrade it...question is how many hp i got now?
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Base Engine L05 from Caprice
Engine was fully rebuilded:
all new bearings , pistons + 0.20
new vortec heads GM Performance 12558060
Valve springs CCA-981-16
Camshaft CCA-08-500-8
Vortec Intake EDL-2116
Drive Pulleys MCH-22031-09
Water Pump EDL-8811
TBI Holley 502-6
Headers HED-68478
EEPROM chip police Hypertech 121461
tell me please now many horsepower my engine is got now ?
Thanks . Dmitry Kiev Ukraine
Water Pump EDL-8811
TBI Holley 502-6
Headers HED-68478
Transmission: 4L80E/4L80E
You will certainly feel a much bigger punch when you get on the throttle.
You will be in the 275-300 horsepower range.
Car: Firebird 91
Re: I swap V6 to V8 L05 and upgrade it...question is how many hp i got now?
aproximately 3.500 $ with shipping from US to Ukraine
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
That chip is not going to work properly with the rest of the engine parts. It will run very lean at WOT and moderate to high engine speeds. You also didn't say what size injectors you are using.
To make the combination work to its fullest you need to retune the chip. The cam you chose is slightly warmer than an F/Y car LT1 cam, so if everything was tuned right, you should have close to 300 fwhp. A decent Vortec 350 build, using a much hotter cam, can go easily over 400 fwhp when tuned properly. Your don't have that, yet. BE CAREFUL because you could ruin that expensive engine.
Car: Firebird 91
Injector is Holley 670cfm , where i can get a properly bin file for this chip ?
Engine: LO3, LO5
You should start by reading in these two things:
https://www.thirdgen.org/forums/tbi/...free-tune.html
https://www.thirdgen.org/forums/diy-prom/
86White_T/A305
Sep 21, 2015 05:28 PM
