gm crate not for 78 and newer??? huh?
Old Jun 13, 2008 | 04:13 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
i am looking at some gm crates and all i read is for 78 and earlier models not meant for street use. i want to keep my egr system and my stock aluminum intake. is the intake manifold the only thing that makes it a non emissions motor.
what about all the block sensors that i have on my L69 now? will they be on the new block. not sure what i'm supposed to do here. i know poeple are implanting 350's into these cars what are they doing about the egr and block sensors. they have to come on the new block right.
can someone please tell me what motor i need to be looking at. h/p betweet 300 and 450. sorryif this is all stupid ***** but i really need some help here.
thanks alot.
Jay.
Old Jun 13, 2008 | 04:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: gm crate not for 78 and newer??? huh?
You can ask about a 50 state legal crate motor.
Or buy a long block, then just put your intake, carb, etc on it. Don't go too aggressive on the cam/heads of the new engine and you'll be fine. Screw in your O2 sensor and the rest is done.
PS - Good picture, that's a sharp looing car there. Wish mine looked that good.
Old Jun 13, 2008 | 10:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Here you go:
http://www.yearone.com/serverfiles/p...12AZ73498&trk=
If that doesnt work then go to yearone.com and look at Chevrolet then 82-02 Camaro, then Power Crate engine assemblies, then its part number CT350PC1.
Old Jun 13, 2008 | 10:35 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
thanks man alot man. thats actually the good side. it goes in next week for the body work to get done. i've some work to get her road worthy again,but she's coming along. when i get her back from the body man i'll tag it up and drive it. thanks on the engine thing too. thats what i thought. i'll re-use my fact mannifold since its alum.
can i use my L69 heads on this 383 stroker. i know its not flat top pistons,but u get the i dea
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
