BB Engine Swap tranny & rear question
Old Jul 7, 2008 | 07:30 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
Re: BB Engine Swap Header
i have a 350 right now on my 86 camaro im thinking of going with 454 bbc and a 100 to 150 shot of nos and i wanted to know if the turbo 350 and a stock rear end can take it?
Old Jul 15, 2008 | 09:56 PM
IrocSS85's Avatar
th350 sure if its built right, forget about the stock rear end. it wouldnt take long.
Old Jul 15, 2008 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: BB Engine Swap tranny & rear question
Depends what you do to the BBC. I never had a TH350 behind a BBC. When I was using a smaller BBC, I had a TH400 for about a year before swapping to the powerglide.
I pushed a beefed up 10 bolt into the low 11's before swapping it out for a 9". Factory cars have also broken 10 bolt diffs on the street. No matter how much you try to beef it up, the weak link will always be the tiny ring and pinion.
If you plan on making any kind of big power with the engine, upgrade to at least a TH400 and a 9" or 12 bolt diff.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
