swapped 305 tbi to 350 carb...but need some info
Old Jul 8, 2008 | 09:14 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
ok so i did the swap and i was originally going to go with the tbi...well to be exact im going to just when i get a little bit more money im low on funds. anyways im hard pressed to remember which wires from the distributor are the ones i use for power and tach...or can i use the stock 305 distributor i have most of the sensors hooked up i just dont have a egr valve right now and the tbi unit as the computer would need to be reprogrammed...so does anybody have an answer for this?
Old Jul 8, 2008 | 09:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: swapped 305 tbi to 350 carb...but need some info
You can't use the stock TBI distributor, you need a non-computer one with mechanical advance.
Old Jul 8, 2008 | 11:38 PM
GMZombie's Avatar
ok with the older HEI distributor which wires am i supposed to use for the battery and tach wires for the HEI cap.is it the wires that are the pink and white plug that would goto the ignition coil or one of the wires that would goto the tbi distributor.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
