1985-1991 vette engine
Old Jul 10, 2008 | 10:39 PM
wht91z28's Avatar
Car: 1991 camaro z28
Engine: 305cu/tpi
Transmission: auto
Has anyone on here ever put a 1985-1991 vette engine and manual transmission in their tpi z28? if so how hard was it and how well did it work out?
Old Jul 11, 2008 | 03:17 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: 1985-1991 vette engine
well i didnt put the vette engine in mine but it was there when i aquired the car. i have a 1986 iroc 350 TPI but its a auto trans. no problems here. it SCREAMS!! good luck
Old Jul 11, 2008 | 06:41 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
same motor with different heads and cam as the l98 that came in f-bodies. Don't know about the trans, you ask me its not worth the swap. But it should be pretty easy. if ur car is an auto some cutting may be neccesary but if you already have a manual it should be a direct swap. If I was going to go through all the trouble I'd do a LT1 or LS1 and a T56 6 speed.
Old Jul 11, 2008 | 11:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cutting for auto transmission???
'86-1/2 - up Vettes had aluminum heads, which didn't have the exhaust cross-over passage. Exhaust was plumbed up externally from the exhaust manifold to the EGR valve on the intake. Not a biggie.
Vette accessories and oil pan/oil pump pick-up won't fit. Transfer them over from your 305 (unless '85 Vette - your 1-piece rear main seal oil pan won't fit a 2-piece rear main seal block).
Vette transmission won't have torque arm mount.
Old Jul 11, 2008 | 11:55 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, cutting for the shifter to put a manual in if it's an auto now.
Old Jul 11, 2008 | 12:39 PM
five7kid's Avatar
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
