305 to 350
Old Jul 12, 2008 | 09:15 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
305 to 350
Getting ready to take out my 305 and have a couple questions
1. with taking none of the body apart like the whole front end will my engine and tranny still together have enough room to squeeze out.
2. I'm switching to a 350 turbo trans. I have to buy a different cross member correct.
3. will i also need a different trans tourque arm.
thanks for any help also whith the new motor the car is going to be computer free.
Old Jul 12, 2008 | 09:20 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: 305 to 350
obviously your hood will have to come off period. and yes it will come out as one assembly with the trans crossmember off the car. yes a different torque arm and trans crossmember is needed for the particular trans your swapping to, but Spohn makes a complete crossmember and torque arm assembly for swaps like this and the torque arm mounts to the crossmember instead of the transmission.
Old Jul 12, 2008 | 09:52 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 305 to 350
for your help I'll check that kit out.
Old Jul 12, 2008 | 10:27 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 305 to 350
had a couple other questions a forgot about. sorry.
4. Can you fit true duals on these and if yes will it fit with subframes that cross connect.
5. I'm assuming that if in need a different cross member i will also need a drive shaft.
Old Jul 13, 2008 | 11:05 AM
72vega's Avatar
Re: 305 to 350
yes a longer driveshaft is needed and true duals can be done, but its ALOT of work.. heres some examples ive come across and saved...
heres the pipes that goto the axle. note the h-pipe the person installed and the absence of cats..
heres what it looks like going over the axle. TIGHT fit
and heres the mufflers..
note* not my pics, just came across them to use as examples!
Old Jul 13, 2008 | 01:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 to 350
Do yourself a favor - take the radiator out first! No matter how careful you are, a hole always gets poked through with a swap!
Old Jul 15, 2008 | 04:00 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: 305 to 350
both.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
