help...
Old Aug 5, 2008 | 07:52 PM
sloviks88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8l v6
Transmission: t5
help...
okay i read the sticky n it didnt have the info on gauges... im goin from a 2.8l mpfi to a 350 carb... what do i do about my gauges??? will they still work?
Old Aug 5, 2008 | 08:43 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: help...
Your speedo will be off unless you swap the speedo gears (since I'm assuming your 3.73's aren't in right now). Other than that, I think you're fine. Somebody else might know more, though.
Old Aug 5, 2008 | 10:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And I quote from the sticky:
"9. The engine control module (ECM) from the V6 won't work. Use a V8 ECM. (You may be able to just change the PROM, depending upon the V6 & V8.) The V6 tachometer has a different resistance than the V8 tach. You can change the resistor, but it's typically easier to just get a V8 tach."
The rest of the gauges weren't mentioned because they will work. You may have oil pressure range issues, but that's another of the "many possibilities" variables that either you can figure out, or ask about.
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
