2 Bolt Main Dart Block
Old Aug 11, 2008 | 10:56 PM
383RS's Avatar
How does a 2 bolt main Dart block hold up against a 4 bolt 350? Is it stronger, just as strong or weaker? Its for a 383
Old Aug 11, 2008 | 11:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Dart block would be superior to any factory block, even if the Dart is 2-bolt main.
Any particular reason you're going with the 2-bolt main, other than slightly lower price?
Old Aug 12, 2008 | 12:07 AM
383RS's Avatar
Re: 2 Bolt Main Dart Block
Ya its in a crate motor. How much 'tougher' would a splayed block be?
Old Aug 12, 2008 | 05:10 AM
wikd's Avatar
as an example... 2bolt is strong... a 4 bolt is 10 times (just an example)... and a splayed 4 bolt is 30 times stronger (again just an example)...
Old Aug 12, 2008 | 11:45 AM
five7kid's Avatar
2-bolt blocks are stronger in the main bearing web. 4-bolts prevent cap "walk" but weaken the web. Splayed 4-bolt mains lock the caps in place without weakening the web.
2-bolt blocks were used exclusively through 1967. If you think no power was made with small blocks until after 1968, you need a history lesson.
Bottom line: 2-bolt blocks are very capable. 2-bolt Dart blocks are even more capable. Splayed 4-bolt Dart blocks are awesome.
Old Aug 12, 2008 | 06:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For the average person, a 2 bolt block is more than strong enough. It's when you start to use huge amounts of a power adder that the extra bolts in the mains are really required.
Reddeath210
Oct 6, 2015 08:20 AM
Accerrito22
Aug 23, 2015 07:22 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
