305 roller?
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
305 roller?
there is a 91 bird in a local yard with a lo3 origional with low miles. is it a roller? is 150 worth the work of yanking it at the yard? i plan on using it for my tpi build. thanks
Transmission: 4L80E/4L80E
The block is the only thing "worth" anything. $150 is too much.
Don't you already have a 350? A 305 would be a downgrade.
Re: 305 roller?
i have a 3rd hand 350 .040 over with blow by. the lb9 i pulled out had more"*****" than this "357".
and i belive i have a rounded lobe on the #3 exhaust valve. the lifter barley moves and ticks
Last edited by vasquezmrysvll; Aug 13, 2008 at 05:47 PM. Reason: Automerged Doublepost
That would explain the lack of umph.
If the 350 only needed rings, it may be worth it to do the glaze breaker thing, new rings, new bearings, new cam & lifters. Probably has lame heads on it as well.
Many 350 blocks can be punched out to .060" over. A sonic check of the cylinder wall thickness would have to be money better spent than on a JY 305.
No 350's in the yard, eh?
Re: 305 roller?
there is a 96 chevy truck with a vortec and a massive lower end knock. other than that, only 305's.
I'd pay $150 for a '96 Vortec 350 engine with a lower end knock in a heartbeat.
ambainb
Apr 25, 2016 09:21 PM
