Purchased a camaro wih a engine swap and need some help
Old Aug 15, 2008 | 10:41 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
ello guys here is my predicament.
I bought a 91 vert RS. carfax says CONVERTIBLE
5.0L V8 TBI OHV 16V / REAR WHEEL DRIVE. The engine in it now is carb'd nd apparently is a 350 wit roller tip rockers, high compression and a mild cam. The issue that I am currently having is I want to know what I have under my hood. Im new to camaros and have speent some time loking around this forum for info. im now stumped so im asking for help.
where do i need to lok to find out what 350 i have under my hood? the engine has only 8k on it right now so i would prefer not to disassemble unless i have to. Is there a way to decode the VIN to find out what trany i have also? its an auto with AOD and its the origional from when it had the 5.0l in it.
Any info would greatly be appretiated guys and hankyou in advance.
J
oh heres a pic of the car for those who are curious nd another of the enginebay
Old Aug 15, 2008 | 10:50 PM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
Re: Purchased a camaro wih a engine swap and need some help
looks like a all stock TBI
Old Aug 20, 2008 | 12:07 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
It does look all stock but that doesnt mean it is. If it is carbed than to confirm just remove the air cleaner and confirm it its carbed or TBI and to see if it has roller tips like state you need to remove one valve cover, i recommend the drivers side much easier. You need to get the number off the block to see if it is a 350 block.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
