510hp/458tq 350 for under 3k!!!!!
Old Aug 20, 2008 | 01:29 AM
Kempfs92's Avatar
Car: 1992 rs
Engine: 305, soon to be 383
Axle/Gears: 373
So I made a 350 that made 510 hp/458 ft pd on the dyno, engine for under 3k,Using some new and used parts
I normally go early to swap meets,and find bargains. And some left over parts I had laying around,I dnt have a car to put this engine in,tho
It ended up being $2958,parts were 2,216 and labor was 742.
My dad helped me,and my uncle
Here's what I had to work with,
Core: from a salvage yard ,long block assembly.
Block; 010 truck block
Pistons: Ross lightweight flat tops
Head gasket: FelPro
Final cr : 12.2:1
Crank : re worked 5140 chevy "cool cased"
Rods: Crower 5.7 rods
Oil pump ;big block
Pan: Moroso
Cam: Roller,Comp cams profile 296-2 intake/exhaust profile on 108 LCA
Lifters Crane
Valve Train: Comp cams 1.6 intake,1.5 exhaust,comp cams pushrods,springs and roller chain timing set.
Heads : 186 with full porting; 30- degree intake; angle milled bronze guides (265cfm @ 700 lift)
Intake: ported Victor jr. With 2 in spacer
Carb: reworked 750 Holley, with 850 base plate; 930cfm
Air filter: K and N
Ignition:HEI with MSD module
Plugs/cables MSD
Header: Walker 1 3/4 inch with 18 inch collector extension
Mufflers: open exhaust for now
Its nice still living with my parents,lol
Just having to pay insurance/gas.
510 hp from new/used and left over parts!!!!!
dropping this in my 92 RS
Old Aug 20, 2008 | 12:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 510hp/458tq 350 for under 3k!!!!!
This reads suspiciously like an article in a magazine... Where they like to brag about getting parts used, "diamond in the rough" parts, machine work that came from a "friend of a friend" so it was dirt cheap... Then they brag about how it only cost xyz dollars. I have some colorful language for people like that you know. Why? Because it only angers the rest of us who DON'T know people who port cylinder heads for free, do CHEAP/FREE machine work, and are giving away nice parts. Good for you, the rest of us have to deal in the world where things aren't given to us. To me you're like a guy who won the lottery and bought a ferrari.
oh, PS - throw more info in that eh? what's the cams part number? what's the head flow at a realistic lift number, like .500"? What's the overbore? deck the block? line hone? which rockers, stamped, full roller, aluminum, etc? etc etc?
oh, and what are you going to do with a 12.2:1 engine anyway?!?
Old Aug 20, 2008 | 01:44 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Well I doubt he's running it on pump gas.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
