305 tranny?
Car: 1986 pontiac firebird
Engine: 305 tbi
Axle/Gears: stock
305 tranny?
im doing a swap from my stock 2.8l engine to a 305 can i just leave my stock 86 firebird tranny in the car or should i get a new one? and if so which ones will be good for it without me having to change alot on the car
thank you in advance
Transmission: 4L80E/4L80E
As the V6 to V8 swap sticky says, the V6 transmission won't bolt to a V8.
If you get a V8 TH700R-4, it will bolt to the engine, and connect to everything else just like the V6 transmission did.
The 4.3l V6 TH700R-4 is the same as V8 transmissions, so if you find one of those from an S10 or Astrovan, those will also work.
Let's get this straight: Both the V6's and V8's use the TH700R-4 from 1984 on. But, the V6 TH700R-4 will not bolt to a V8. So, even though they are called the same thing, they are different. You can't make a V8 TH700R-4 from a V6 TH700R-4.
Engine: 305 tbi
Axle/Gears: stock
Re: 305 tranny?
ok thank you im sorry about this i trying to get as much info as possible and ive been reading for days i really appreciate all of this
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
