305to 350 tpi question
Old Aug 17, 2008 | 12:07 PM
greghatfield82's Avatar
I just bought an 86 iroc and the previous owner took out the 305 tpi and put in a crate 350. The motor runs HOT!!! and i was told that i need to have a custom burnt computer chip because the car is still sending air and fuel to a 305 causing the new motor to run lean which = heat. My question is can i use a chip for an 87 witha 350 or do i really need to have one burnt? I'm not really good at this stuff yet so as simple as you can make it would be great. Thanks for your time. All the other components have been checked......air dam, water pump,radiator, thermostat, fan, so i'm thoroughly confused
Old Aug 17, 2008 | 07:31 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: 305to 350 tpi question
so the car is a 350 w/305 tpi correct?
If so,theres a few parts you'll need.
you will need a 350 chip,inj.,knock sensor,esc module,and I believe thats about it.
Old Aug 17, 2008 | 08:01 PM
So do i just go online and get a chip for like an 87 w/ a 350? or is there a certain one i need? Also what is the esc module? and what company is the best to get these parts from? Sorry for all the questions i am still pretty new to this stuff.
Old Aug 18, 2008 | 12:49 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
That's right. You'll need a chip for a 350, and injectors. If it's a stock 350 with a stock cam then just find out what year car the motor came out of and car if possible. Then see if you can get one. The ESC is the Electronic Spark Control. It uses the knock sensors to retard the timing if detonation is detected.
Old Aug 18, 2008 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't "need" a 350 chip. '86-'89 were MAF, which isn't as sensitive to mapping. You might get a little more power out of a 350 chip, but you'd also get more power with PROM tuning. '89 didn't have the cold start injector, so the only "stock" 350 chips you should consider are '87-'88.
Where is the timing set? Was it set with the ESC wire disconnected? Retarded timing is much more likely to cause overheating than a 305 MAF chip.
Old Aug 18, 2008 | 05:46 PM
I'll have to have my buddy come over and check the timing. Where should it be set? The motor that went in was a crate motor about 4 years ago so i'm not sure what cam is in it or of the injectors. I'll look into these as soon as possible.
Old Aug 18, 2008 | 05:51 PM
five7kid's Avatar
6 degrees BTDC with the ESC wire disconnected.
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
