305 TBI to 350 TPI
Old Sep 4, 2008 | 03:24 PM
VAFIREGUY's Avatar
Re: Pontiac V8 Swaps
I HAVE A 305 TBI IN MY 91 FORMULA AND JUST GOT A 350 TPI WHAT DO I NEED TO DO TO GET THE SWAP DONE
Old Sep 4, 2008 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
First, I moved this from the "Pontiac V8 Swap" sticky because your question isn't what that thread is about. You have a small block Chevy in your car, not a Pontiac V8. If that revelation causes you some psychological damage, well, sorry, sometimes the truth hurts.
Now, what all of the "350 TPI" did you get? Engine, TPI hardware, harness, sensors, ECM, fuel pump, throttle cables - hopefully you got all of that, or can go back and get it. With all that in hand, remove the 305 and TBI stuff, and put the above 350 and TPI stuff in.
What did the 350 TPI come out of?
Old Sep 6, 2008 | 07:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 305 TBI to 350 TPI
There is a tech article on this website on the main website page that details the TBI to TPI swap. There are also hundreds of posts from members who have done the swap that you can and read and learn. Good luck!
Old Sep 9, 2008 | 12:19 PM
VAFIREGUY's Avatar
I GOT EVERYTHING BUT THE FUEL PUMP AND THE 350 CAME OUT OF A 91 FORUMLA
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
