ID a V8
Old Oct 14, 2008 | 09:54 PM
nerv2112's Avatar
Car: '84 Z28 H.O.
Engine: Swapped 350 with Q-jet
ID a V8
Hey all I have seen the sites showing where to look for casting numbers and the like on engines but I cannot seem to locate the one on the back of this one. I would like to find out what is in this car for sure.
I was able to locate one number below the head on the passenger side that reads: M09219VP but so far that number has gotten me nowhere. The engine is supposedly a crate 350 but I have nothing to verify that other then the previous owners claims.
The car this is in is a '84 Z28 H.O. I suppose there is a possibility it is the original engine.
Old Oct 14, 2008 | 10:11 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: ID a V8
http://www.mortec.com/castnum.htm
This site may help you out.
Old Oct 14, 2008 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ID a V8
I'd look at the M09219VP again. Although it may be a code for a crate engine, 9VP is not a production code. If the letters are clear and defined, then it's not a production engine.
The casting number is at the back left top of the engine. You have to look down between the firewall and the head to see it. A casting number can tell you if it's a 4" bore block or not for an easy check to see if it's a 305 or a 350 but the casting number can't tell you much more since the same castings were used over many years and in many models.
Old Oct 15, 2008 | 11:44 AM
nerv2112's Avatar
Car: '84 Z28 H.O.
Re: ID a V8
The number is pretty clear although the 0 could be an O I guess. It seems to have one of the short water pumps on it and hardware. I could not see well enough behind it even with a mirror to get any meaningful numbers off the back I will try again later today
Old Oct 15, 2008 | 11:52 AM
nerv2112's Avatar
Car: '84 Z28 H.O.
Re: ID a V8
Here is what it looks like although I know it doesn't help much.
Old Oct 15, 2008 | 03:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's a standard long water pump.
Can't tell from that photo whether it's a 262, 265, 283, 302, 305, 307, 327, 350, or 400.
Odds are it's a 305. It looks like a stock 305 with AC and dual snorkel removed, and chrome valve covers and open element air cleaner.
Old Oct 15, 2008 | 06:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: ID a V8
Because the alternator bracket is attached to the water pump, it will be a late model long water pump not a short one.
The 0 will be a 0 and not an O. I guess I should have looked up the full number.
M = GM of Mexico. It's not original and I doubt it's a performance crate engine but more likely a Targetmaster engine. (standard factory replacement engine with good but not performance castings)
0921 = Sept 21
9VP = Whatever the replacement engine code is. I don't have a listing.
The engine is definitely not original. Get a casting number to see if it's a 350 or a 305. There may be a casting on the side of the block. If the block is new enough, there will be a 5.0L or 5.7L cast into the side.
If you pull a valve cover, you will see Hecho en México cast into the head.
Old Oct 15, 2008 | 07:39 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: ID a V8
standard factory replacement as in warranty engine? that could explain the po claims of a crate motor
Old Oct 15, 2008 | 08:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ID a V8
Not necessarily warranty, but a generic low-performance over-the-counter replacement engine.
Old Oct 16, 2008 | 04:11 PM
Brennan's Avatar
Re: ID a V8
well if i was a betting man id say that he got that targetmaster engine and technically it would be a crate engine
Old Oct 16, 2008 | 07:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: ID a V8
Any aftermarket engine would be considered a crate engine. Most people think of a crate engine as an aftermarket performance engine. The Targetmaster is just a factory replacement engine. Built to factory specs with factory production parts. Nothing special.
Old Oct 17, 2008 | 12:33 AM
nerv2112's Avatar
Car: '84 Z28 H.O.
Re: ID a V8
Hey thanks for the help tracking this thing down you guys I am really happy I found this site and there seems to be so many fans of these cars still.
I finally was able to find the casting number.. It is as you all suspected a Target Master 350 according to MorTec. No date info though.
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico"
I found this info on another site I have no idea how accurate it is. Maybe you guys can tell me.
350 Cubic inches 4.00" Bore, 3.47" stroke
8.0:1 compression ratio.
250 HP @4300 rpm 350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036 2 piece rear main seal 4 bolt main
Crankshaft- part # 3932444 Nodular Iron 1985 and older flywheel bolt pattern.
Connecting rods- Part # 10108688 Powdered Metal
Pistons- part#12514101 Cast Aluminum
Oil Pump- part # 12555284 G.M. High Volume Pump
Camshaft- Part#3863151 Hydralic Flat tappet
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194° Exhaust Duration @.050"- 202°
Lobe Seperation-112°
This cam Has a mechanical Fuel Pump Lobe. This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808 casting #33417369
1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
7 Bolt style Exhaust Flange Standard 85' and prior intake manifold bolt pattern.
Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
Old Oct 17, 2008 | 12:56 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: ID a V8
Sounds like a basic factory stock replacement engine. Something you can pick up just about anywhere that sells a replacement engine including NAPA.
Old Oct 18, 2008 | 05:05 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: ID a V8
According to Kevin McClelland of Flowmaster (muffler company) who used to work for GM, they actually ship at 7.8:1, and they really like the COMP PureEnergy cam, COMP's DualEnergy 255, Lunati's smallest VOODOO, Or Crane's 204/214-110 442/465 cam, and 1.6:1 rockers on the intake side, after break-in.
