engine swapping
Old Nov 4, 2008 | 03:19 AM
hybr1d's Avatar
Car: 92 Z28
Transmission: 4-speed auto
engine swapping
What would be the easiest swap for a 92' z28? im looking for a turn key engine that i get put in with the stock brackets or VERY little modification. I wont be doing it myself i have a shop for it. im on a budget, $0-$3800, either new or used i dont mind can anyone give me some links to some.
On a side note what is the avg. cost of a engine swap?
Thnks
Old Nov 4, 2008 | 02:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're not going to want to hear this, but it doesn't exist. I assume this is a TPI 305, in which case you need different injectors, knock sensor, and PROM tuning, which you aren't going to get with a new or rebuilt engine.
You could do a rebuilt like this - http://www.rebuilt-auto-engines.com/...34108508830.82 . By the time you add shipping and core charge, you're up to about $1850. You'd still need the above parts. Install will run you about $1000.
Or, you could go with a specialty new engine like https://plmcev.ast.lmco.com/Windchil...235413201&u8=1 . You'd need the Paragraph 1 parts above, plus shipping, plus aftermarket runners and TB, plus the same $1000 install.
The rebuilt example is probably the closest to achieving your goal within your budget.
Old Nov 5, 2008 | 02:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engine swapping
, more or less.
Old Nov 5, 2008 | 07:32 PM
hybr1d's Avatar
Car: 92 Z28
Re: engine swapping
thanks alot, another question i got is i heard there are LS1 conversion kits, with the conversion kit does it just change the where the engine bolts in? but all in all i think im going to get the engine rebuilt, but if it is possible i would buy a LS1. Again thanks
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
