89 Iroc BBC sway bar clearance
Old Nov 20, 2008 | 10:51 AM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
I have an 89 Iroc, I just bolted in a 454 bbc with a th400. The problem that I have run into is that the crankshaft pulley looks to be sitting on the sway bar.
Has anyone else run into this problem? What do I do to correct this? Sorry about the size of the pic, I don't know how to make it a thumbnail.
Old Nov 20, 2008 | 01:12 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 89 Iroc BBC sway bar clearance
I would think different diameter pulleys would solve the problem.. it does look pretty close, is it actually touching?
Old Nov 20, 2008 | 01:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you put in new engine mount inserts, poly, perhaps? Stock rubber ones sag over time.
Do you have the back of the engine at the proper height?
Old Nov 20, 2008 | 01:59 PM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
I am pretty sure it is touching
Old Nov 20, 2008 | 02:07 PM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
I don't have the trans crossmember in yet, I have the spohn piece with tq arm relocation. The trans is on a jack. I have not replaced the mount inserts as of yet.
Old Nov 20, 2008 | 05:36 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i would surely change the mounts inserts to see if it helps. not only r they probably wore out but they also have one heck of a heavier load on them with a iron headed BB.
Old Nov 20, 2008 | 05:57 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I had the same pulley on my bbc and it was not a problem, I wouldn`t worry until it is all bolted up, new poly mounts or a under drive pulley would fix it if ends up too close
Old Nov 20, 2008 | 08:05 PM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Which mounts did you use? I used all the stock 305 hardware, on both the block and frame mounts.
Old Nov 21, 2008 | 05:36 AM
same here..stocker 5.0 stuff
Old Nov 21, 2008 | 06:15 AM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
thanks to all of you. I look forward to driving this car next summer. It will be going down after that for a rebuild for the winter.
Old Nov 22, 2008 | 05:39 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You can always space the swaybar down away from the frame by a quarter inch, even if you just use longer bolts and some washers, until everything's finalized.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
