i need info
Old Nov 24, 2008 | 07:06 PM
wildchildracing's Avatar
i need info
ok so i decided to ditch the 327 and 454 and just get a regular 305 ho. but ive had many people tell me it will take alot of work to change a motor that has a throttle body to one that is carburated. my iroc is an 87 and it has a 305 tpi. the motor i got for it is a 305 ho. what kind of things to i have to change for this motor to work in my car
Old Nov 24, 2008 | 11:04 PM
toomany's Avatar
Re: i need info
I isn't that much work. I think it's harder to go the other way (carb to efi). Have you read this yet? https://www.thirdgen.org/carbswap Some good info there.
The motor swap should be pretty straight forward. Basicly remove and replace.
As for the fuel pump. You can use the stock one, and run a bypass regulator to send the excess back to the tank. However I have heard of this not lasting very long though. IDK. I've swapped to carb on a TBI motor and used the in-tank pump. Haven't had any problems with it yet.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
