498 on engine test stand.
Transmission: 4L80E/4L80E
I'll bet you made the neighbors real happy.
Wait, "West Texas". Never mind. . .
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Re: 498 on engine test stand.
The runs on the engine stand were made at the engine builders , outside his shop. His neighbors should already be used to the noise of the place.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Sounds real nice should be quite a stump puller
Car: 86 z28
