Building a 383. Parts List?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Okay, Im trying to get a 383 built up from scratch, and installed into my trans am, by christmas time.
Parts I have:
.030 Pistons w/ Valve reliefs
.030 Rings
5.7 PM Rods
Parts On Order:
Assembly Lube
Hi-Vol Oil Pump
Timing chain Set
Plug Wires
Freeze Plugs
Parts I need to get:
383 Crank 2pc rms
Gasket Set
Bearing Set
Camshaft
Is anything missing from my lists?
What cam do I need to go with a 383, that will be daily driven? Im not above using summit or jegs brand items, as long as the quality is there. I would prefer a good cheap kit, that comes with the cam, and lifters.
Can someone please link me to some part #'s, that will work with my build?
Part #'s of things I need will be:
Cam Set
Bearings, 350 block, 383 crank, standard size
Valve Springs
Push rods
This is a Budget build, and I need all the help I can get, I greatly appreciate the help.
Parts I have:
.030 Rings
5.7 PM Rods
Parts On Order:
Assembly Lube
Hi-Vol Oil Pump
Timing chain Set
Plug Wires
Freeze Plugs
383 Crank 2pc rms
Gasket Set
Bearing Set
Camshaft
Cam Set
Valve Springs
Push rods
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Building a 383. Parts List?
Federal Mogul 4663 main bearings, 1235 cam bearings and 2555 rod bearings. Use whatever springs the cam manufacturer recommends, and whatever pushrods you need for your heads after you've measured after assembly.
Are these what your talking about?
Main- http://store.summitracing.com/partde...M&autoview=sku
Cam- http://store.summitracing.com/partde...M&autoview=sku
Rod- http://store.summitracing.com/partde...P&autoview=sku
When it says ''Sold Individually'' does that mean 2 pieces, for 1 rod, or one side of one rod, I dont want to order 8, to find out I need to order 16.
Do you have any suggestions on a cam/lifter combo I should get? Can I get away with a set of stock heads, with just some new springs?
Thanks so Much for your help.
Rods I Have:
http://store.summitracing.com/partde...1&autoview=sku
Pistons I have:
http://www.jegs.com/i/Sealed+Power/844/345NP30/10002/-1
Rods I Have:
Pistons I have:
Engine: 383 Carb
Transmission: 4L60
"Sold individually" means both halves for one rod. Easier to get a set of 8 instead http://store.summitracing.com/partde...P&autoview=sku
You can't use those rods and those pistons to build a 383.
Engine: 383 Carb
Transmission: 4L60
Those are 350 pistons with a 1.54" comression height. With a 383 crank they're going to stick up out of the block and smack into the heads. You either need to use a 5.565" rod, or use a piston with a 1.4" compression height
Oh.. Nobody ever told me that..
Well, I can't afford getting new rods or pistons, should I just go 355?
What are the Power gains between a 383, and a 355?
Have any Cam Reccomendations for a 355?
Engine: 383 Carb
Transmission: 4L60
Just get a 350 crank if you don't want to change rods or pistons.
Pick a cam that works well with the heads you'll be using.
Ive got a couple different sets of heads. Ill just be using some stock 350 heads, will they suffice? What kind of work will have to go into them, Ide like 300-350 HP..
1992 Trans Am
05-10-2023 07:19 PM
