can i use throttle and kickdown cables from tpi?
Old Dec 26, 2008 | 01:33 AM
73duster's Avatar
do i have to change the throttle and kickdown cables when i go carburated from tpi? or is there a special bracket i have to get for attaching to carb?
Old Dec 26, 2008 | 02:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: can i use throttle and kickdown cables from tpi?
The cables are different.
Keep it TPI and save that hassle.
Old Dec 26, 2008 | 04:28 PM
73duster's Avatar
i appreciate your strong feeling towards keeping the tpi setup, but i don't know enough about diagnosing fuel injection and dealing with ecu programming. Also i've been doing a lot of searching for making good power with tpi and it's way too costly and too much work. I've made up my mind and am sticking with tried and true carburation. When something goes wrong, and they always do, at least i can troubleshoot things myself. I know i can drop a 400 hp 383 in and get it running pretty good and i like the simplicity. So that being said, i'd like a solution to my original question. Thanks
Old Dec 27, 2008 | 10:37 AM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
I am switching from crossfire injection to a carb and ran into the same problem. It is going to depend on what intake you use. I had to get new cables and a special bracket for the cables. However, the throttle cable is about 1/4 inch too short so I have to figure out a way to extend the cable.
Old Dec 27, 2008 | 11:26 PM
blp226's Avatar
Tell the parts house you want throttle and TV cables for an 84 Z/28. They were carberated that year. The company that made your carb will have the brackets that you need to properly attach them. I changed the 305 to a 383 with a holley 770 carb. It took two seperate pieces for the attachment. One actually holds both the cables, the other hooks up to the throttle itself to properly allign the TV cable.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
