Questions about engine swap and transmission.
Old Jan 8, 2009 | 10:01 PM
87GTACamburke's Avatar
Car: 1986 Pontiac Firebird
Engine: 305 4bbl
I have a 86 Firebird,its got a stock 305 Carb. Im getting a 350 from a 69 Firebird. I was wondering if the stock transmission which is a 700r4,would handle the 350,and would it even fit in right.
thanks. Cam
Old Jan 8, 2009 | 11:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Questions about engine swap and transmission.
It will fit fine.
Old Jan 9, 2009 | 12:49 AM
ljnowell's Avatar
Is it a chevy 350?
Old Jan 9, 2009 | 01:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Grr, forgot about the Pontiac 350.
If it's a Pontiac 350, no the transmission won't fit. That doesn't matter much though, because the engine won't easily fit the car either.
Old Jan 9, 2009 | 09:04 AM
Engine: 305 4bbl
ahh damn,alright, thanks. well it'll still be a good motor to work on hahah.
Old Jan 21, 2009 | 10:26 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
buy the adapter to re-use your chevy transmission and then you only have the engine issue to work out.
We will be standing by to see if you can do it!
Good luck!!
Old Jan 21, 2009 | 02:42 PM
ljnowell's Avatar
Good luck!!
Way to much work for a 350ci engine.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
