question on 85 z28 motor an trans swap
Old Jan 9, 2009 | 07:24 PM
DROCZ28's Avatar
Car: 1985 Z28
Engine: Slightly modified carbed HO305
Axle/Gears: stock
will a t-56 bolt to a 60s model small journal 327? i already have pounded bored and cammed 305 hooked to a t-5 and a 327 on a motor stand waitin to go in
Old Jan 10, 2009 | 01:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If the T56 is from an LT1, it can be made to work. You'll need a different flywheel than the LT1 because the 327 is 2-piece rear main seal and the LT1 is 1-piece crank, and they use different flywheel mounting.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
