305 to 350
Old Jan 13, 2009 | 02:26 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
305 to 350
I have a 305 TPI and I plan to swap for a 350 TPI. Will it be just a simple swap of the engine? Or do I need to swap anything else out to go with the 350?
And also if I have a cold air intake on the 305, can it be used with the 350 as well?
Old Jan 13, 2009 | 02:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350
A new knock sensor, injectors and PROM would be a good idea. You can use your cold air intake with the 350.
Old Jan 13, 2009 | 07:07 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: 305 to 350
Oh alright thanks.
Old Jan 18, 2009 | 10:29 AM
Redlined's Avatar
Re: 305 to 350
I too am planning on swapping the block and heads on my 86 TA. But my question is this. What type of blocks and heads can I use. This is my first TPI, but I am not new to mechanics or GM. Can I use any standard 350 block? Seems like the heads dont have the different angle. I have a 350 I built with a Scat rotating assembly, Comp Cam, and some basic aluminum heads. It was originally intended for my offroad truck. But I have been contemplating putting it in my TA. Other than the injectors, PROM, and (why a new knock sensor by the way?) knock sensor, will that motor work for my application?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
