305/350
Old Jan 27, 2009 | 10:49 PM
drfeelgood_88's Avatar
I have a 88 firebird just want opinion on what to do it has a 305 but was wondering if i should keep that motor and build it for power if its worth it or swap it for 350 any info would help
Old Jan 27, 2009 | 10:59 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305/350
Has anything been done to the car already?
Old Jan 27, 2009 | 11:43 PM
Re: 305/350
no its all factory all but a k&n filter but that doesn't amount to anything
Old Jan 28, 2009 | 12:38 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305/350
You can start with things like headers and exhaust. That'll give the 305 some more power, but you can still use them with a 350 later.
Old Jan 28, 2009 | 09:16 PM
camaroz28_'86's Avatar
Car: '86 Z28
Engine: 5.0 305
Transmission: Auto.
Re: 305/350
Last year i found a page were Lunati had a 305 build with a few part variations upping the power and price, but i can't find the web page now. Luckily i wrote down one setup. Lunati used '96-'97 L31 Vortec truck heads p/n 12558060; Edelbrock super victor intake; Holley 750cfm double pump carb; Comp cams X-treme energy hydraulic flat tappet cam grind number XE262H-10; Hedman street headers; and MSD hei fire distributor. Was going to do this build myself but i'm opting to do a 350 stroker to 396 build. Hope this helps.
Old Jan 29, 2009 | 09:33 PM
Re: 305/350
what kind of truck where these heads on and what motor so it will make it easier to locate
Old Jan 31, 2009 | 01:37 AM
Car: '86 Z28
Engine: 5.0 305
Transmission: Auto.
Re: 305/350
If i'm not mistaken they were on silverados and suburbans, and it was the 350. casting number should be 10239906
speedy21cvb
Dec 18, 2003 11:01 AM
