91 305 TBI swap to 88 350 TPI
Old Feb 7, 2009 | 05:01 PM
randybdis's Avatar
Car: 1991 Chevy Mixed Camaro
Axle/Gears: I think 2.77
I Have a 1991 RS Camaro 305 TBI and I just bought a 1988 Iroc Camaro with an 350 5.7 TPI. I want to take out the 305 and put in the 350 to the RS body. but i dont know exactly what i need to swap.
I know I need the ECM, Wiring Harness and Fuel pump from the Iroc how ever i want to make it a stick shift. will the iroc ECM support the T5 from My RS?
Also My dash is max mph is 110 and is a different style from the 88 model. Will it still work after the swap? or what do i have to do to make it work? Because i Just figured i would get the dash out of a 92 Z28
Old Feb 8, 2009 | 12:33 AM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: 91 305 TBI swap to 88 350 TPI
you listed everything you need for the engine swap. the computer should support the t5 the only thing is you might have some idling issues. as long as both speedos are electric or both are cable you will be good there too.
Old Feb 8, 2009 | 03:59 AM
randybdis's Avatar
ok i get what ur saying but.. the top speed on the iroc is 145 and the top speed in my RS is 110..
I was thinking about just getting the dash cluster out of 92 Z28, but i just wana make sure everything works u know?Cuz i dont wana be going 120 and my speedo says 110.?
Old Feb 8, 2009 | 07:34 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
the top speed of the RS is much higher but the computer shuts off the fuel pump at about 115mph.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
