v6 swap
Old Feb 17, 2009 | 09:02 PM
jstringer50's Avatar
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
v6 swap
I know this question is probably on here a million times already but when swapping a 2.8 v6 to a 350 in a 1989 camaro what do I need to do to move the motor mounts and what can I expect in terms of difficulty?
Old Feb 17, 2009 | 09:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I understand this is a very difficult thing, but - read the sticky first: https://www.thirdgen.org/forums/engi...swap-read.html
Old Feb 17, 2009 | 10:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: v6 swap
what he said
'cause I been there, done that
Old Feb 19, 2009 | 06:11 AM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
Re: v6 swap
I read the thread and just want to understand something right quick, when he says "drop the a arm, does that mean dissasemble the entire brake system, shock system, sway bar system, and let the a arm swing down? Or does he mean removing the a arm from the k member from that bolt that makes the a arm swing?
Old Feb 19, 2009 | 09:53 AM
five7kid's Avatar
What you need to do is get the A-arm bushing bolts out and the A-arm off of the K-member, if you're talking about getting to the chassis side mount bolts.
Doing this with the engine out is not an easy task, as the front end of the car, without the engine/transmission, does not weigh enough to keep the spring compressed for this job.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
