duramx!!!! black smoke
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: duramx!!!! black smoke
Im thinking its not going to happen.
How old are you anyway?
COTM Editor
Good luck! Hope your fabrication skills are sharpened. Your gonna need to do some major hacking and welding, to get it under the hood, trans into the tunnel, and exhaust not scraping.
im 20 years old and i dont plain on having it done in like 6 months this is going 2 be a on going thing im shooting for 2013 2 get it done. and my best freind is a welder and im going to school for auto macanics. (but i cant spell worth crap)
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i have always wanted to see a good running diesel in a camaro, i think it would be sweet, but it would be a lot of work, i dont think that duramax is any bigger than a BBC, it just weighs more......id think it would be pretty quick
Car: 1987 IROC
Engine: 5.0 TPI all stock
Axle/Gears: G92 G80
Id think it would break your rear end...make sure you get a dually rear end lol. Those 6.6 duramax's are torque monsters!
Car: '86 Z28
Engine: 5.0
Transmission: m39
this would be hard to do a duramax is a heavy engine, major front suspension upgrades not to mention the car would sit higher off the ground to have proper clearance (you have to bodylift a suburban to get a duramax to fit)
but Ill quit discouraging you "good luck were all counting on you"
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
if it was dooable someone would have done it. its nice to dream tho. every one of my vehicles would be diesel if i could
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
im sure if they can put a diesel in a corvette then can put one in a 3rd gen...
http://www.youtube.com/watch?v=Lw9FTFlSsB0
http://www.youtube.com/watch?v=6JKJXWO6yF8&NR=1
Car: 1989 firebird
Engine: 383
Transmission: 6 speed
Axle/Gears: ford 9" 410
by the #s it should twist a 3rd gen into a knot.... you better put a 16 point cage into it and pray,,,not to say it cant be done but good luck that is going to be a ton!!! of work...
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i saw a video of a deisel in a 3rd gen camaro and i cant find it.its out there somewhere
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
There was a mustang in drag week with a duramax engine in it and it ran low 10s and it had a 9'' or an 8.8 rear in the car. Google 08 drag week.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
worthless swap w/o stacks. don't forget the gearvendors for even more fun
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I think it would be great.
You are correct, there are no limits here. If the engine physically clears the parts it needs to clear most, like the glass, hood and crossmember, there is no reason you can't cut it up and weld it back together. You can even fab a crossmember if you need to.
I'm not sure if I can post links or not, but just check out 'diesel drag racing' or 'diesel performance' videos on the net, it's pretty cool.
As long as you realize the money pit and time frame you are into, it can be a lot of fun and good for your careers if it doesn't interfer too much.
Car: '89 Firebird
Engine: 7.0L
this would be the first time doing a car but i have delt with lifted trucks and i plan on putting a tryangulated 4 link with a gm 10 bolt with 4:11 gears. i all so plan on putting a full cage, boxing the frame where i can. im going 2 try and fab in a front a arms system from a chevy c1500.
Transmission: 4L80E/4L80E
I think you'll want something stronger than a 10-bolt.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
someone tried it in a 69 but scrapped the idea after running into issues http://www.pro-touring.com/forum/showthread.php?t=46534
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
i dont plan on putting the a1000 in it! (trimming the fat) i want to use a 4l80e. if this guy can make it work in a corvette i van shore as hell try it with a camaro!!! its the turbo diesal one
http://video.google.com/videosearch?...iesel+corvette
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Maybe look into one of the older 6.2L diesels. They look almost exactly like a small block chevy and im pretty sure itd be a lot easier then a duramax, I think the motormounts are even the same or at least very similar.
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Better yet why not go with an 871 Jimmy diesel out of an old cement truck. That big 871 huffer sticking thru the hood would look great and the sound of those old Jimmys would turn anybody's head. And you are right about your spelling.
holy crap i never seen the purple vette, that is bad *** if that engine could fit in there i dont see a reason why it wouldnt fit in a third gen. the duramax i have my doubts tho
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
4.11 gears?? Isn't that the total opposite of what you want? You're not going to be pulling a 20,000 lb load of dirt. Doesn't it make more sense to go with lamest gears you can find, ie, 2.41 or 2.29?
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hahaha...Im glad someone else here knows the vette video is fake... Sheesh...
This isnt fake however...no sound dubbing here...and that black smoke isnt photoshopped. haha.
http://video.google.com/videoplay?do...42729641&hl=en
http://video.google.com/videoplay?do...07759731&hl=en
http://www.18to1.com/
Probably the closest thing you'll find to being a cool well running diesel car swap in my opinion.
Ill never say things cant be done. Ive seen some crazy stuff done to cars with a whole ton of people saying it couldnt be. So Im sure this could be accomplished...however I have my doubts in this particular instance. Its going to take a LOT of work to make a thirdgen support a motor like that.
Good luck though if you are actually serious and start to work on it!
J.
J.
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Why not use that baby duramax GM ( i think its 4.5L??) was planning to use in the 1500 trucks. Here is little info http://media.gm.com/servlet/GatewayS...=2&docid=37112
wasn't there talk of that going in the 5th gen camaro at some point?
Car: 87 GTA
Dunno what diesel is in this Vette, but.....Diesels in Vettes are possible, even though this isn't a C5/6.
http://www.youtube.com/watch?v=sAWbD9io6bg
theres not enough room under the hood of a vette for a duramax, let alone a twin turbo one
