3800 Series II in a 3rd gen?
Old Feb 27, 2009 | 12:40 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Hey, so I'm considering pulling out my LG4 and throwing in a 3800 Series II V6 from a 4th gen camaro. Has anyone done this? Is there anything I should know ahead of time? What extra parts would I need from the 4th gen?
Old Feb 27, 2009 | 05:56 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: 3800 Series II in a 3rd gen?
done it. VSS gauge cluster for ease of splicing in the new harness leads. You'll need to fab up some new frame-block brackets. Use a 97+ pcm so you can use either Digital Horse Power or HP Tuners to program it, & also get rid opf teh silly VATS/PASSKEY thing. Custom make y-pipe, don't use the 97~98+ "header" style exhaust manifolds, use the ugly earlier style, they'll clear the frame rails. I also had to fab up an engine bay fuse box (pretty easy really) and routed the wiring under the pass fender. 4L60 swaps no problem, and the ***speedo can be programmed w/everything else.
*** this is why VSS gauage/cars are better for this swap, it just makes things easier.... at least that what I think.
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
