350 HO Swap!!
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
350 HO Swap!!
So I'm doing a swap in my 88 GTA. Swapping the L98 for a 350 HO from GM. This engine is rated at 330hp, and I am going to be adding a Holley Stealth Ram.
I currently have a full exhaust system: Hooker 2055-1 headers, Magnaflow Hi-Flo cat, and Magnaflow stainless steel system.
Would this be a nice set-up?
-For those who know what kind of power am I looking at at the wheels?
-And what pound injectors should I run?
Also I have upgraded with Hotchkis's rear suspension kit and a B&M transkit with ratchet shifter.
Thanks a bunch!!
And is there anything that you guys would not suggest?
Thanks again.
Thanks a bunch!!
Thanks again.
Transmission: 4L80E/4L80E
Although the HSR will help, TPI limits the output of that engine.
A little more money, and will include a base you can't use (could sell it to offset the HSR), but a good performer - http://www.sdparts.com/product/SD360...ripEngine.aspx
Better cam, roller lifters, better heads (the 330 HO is lift-limited).
Re: 350 HO Swap!!
I'm just looking to produce 340-380 hp at the wheels, I don't really want more than 380. It's going to be a daily driver and I want a performer that is going to be built on a budget. Ya know?
The 330 HO is going to be about 75 HP short of 330 at the wheels, let alone 340-380 at the wheels.
Re: 350 HO Swap!!
So you suggest that scoggin dickey crate. . .
Well there is a shop in my city here and he suggests having a 383 but tuned down a little bit. He could get the long block for around 5400$ cnd. That's a good bang for the buck huh?
Whatever power you want/need at the rear wheels needs to be about 25% more at the flywheel. The 330 HP is a gross flywheel rating.
Whether or not you "need" more - well, probably not for a nice running street car.
Re: 350 HO Swap!!
So that 350HO will not bring me to 350 horses?
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
Re: 350 HO Swap!!
http://www.yearone.com/serverfiles/f...26DK73488&trk=
I was looking at the same engine as you over the winter and found there are definitely some better choices out there. This one might be a little more hp than what you are looking for but I think it's a better deal over all. I got lucky and found a nice deal on craigslist, but that's risky too.
Re: 350 HO Swap!!
So it was a direct fit for a tpi car? They're vortec heads which is good because I'm doing a vortec stealth ram.
Just curious what your power is at the wheels?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 350 HO Swap!!
Maybe the following will help perspective a bit: I purchased the 350 HO Deluxe based on a review/build up, dyno test in CarCraft (Feb. 04). With iron exhaust manifolds, 2 1/4" exhaust pipes and a pair of turbo mufflers, the HO Deluxe managed 354 lb-ft of torque and 320 hp (which apparently wasn't the way that GM tested). Throwing on Hedman 1 5/8" long tubes, with no other changes, added 23 lb-ft of torque and 17 hp. The three-part write-up is quite interesting.
JamesC
JamesC
Car: 1987 Trans Am
Re: 350 HO Swap!!
I didn't buy the year one engine. I found one someone else had built part by part. Someone else recommended that year one for my car. I called year one and they were helpful in talking about application. You could try that.
Car: 1987 Trans Am
Re: 350 HO Swap!!
Re: 350 HO Swap!!
Okay, so what do you think of Year One's "Power Crate 400hp 350 crate engine" #CT350PC1? With a Holley stealth ram # 7542P, and fuel rails w/afpr # 534-193, and accel 28 lb injectors, and Holley 58mm throttle body # 112-503, and Hooker # 2460-1 headers w/ custom 3inch ypipe, and Magnaflow exhaust system # 16829.
Would that be a strong set up that would bring me to 350+ rwhp?
Thanks guys!
Thanks guys!
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: 350 HO Swap!!
get the 355
you can toss semi similar parts (price wise) at it and crank out 500hp+
It way out performed the 327 and the 383.
Seems like your gonna spend a lot of money but unsure of what you want.
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
Re: 350 HO Swap!!
is that cam in that thing MAF tunable?
Re: 350 HO Swap!!
Ya, I just want to be in that 350+ rwhp range. But that yearone engine is a 355. . My local shop in the city says they could build a 383 for me but I want a street vehicle to drive to school quite a bit and still get over 20mpg in the city. .
Car: 88 Camaro
Engine: 305 TBI
Re: 350 HO Swap!!
383 is a lil overkill and some reason wont put up as good as numbers as the 355.
I was reading some tech articles comparing the 2
the 383 got low 400's while the 355 got 500+ and was cheaper to build
Id think a 500 hp 355 is streetable
Have you looked in catalogs like jegs and shiznit they have some decent deals on blocks, turn keys, almost complete engines.
Re: 350 HO Swap!!
Ya, that year one engine is 400 hp at the crank. So with good headers and the stealth ram that would put up 380 rwhp I'd say. I don't want to go carbuerated.
Re: 350 HO Swap!!
Oh, but my local performance shop should be able to build me an engine around 380rwhp right?
Re: 350 HO Swap!!
The stock L98 is a puss in the GTA. It's too weak. I want a fun vehicle that would put me in low 13s or high 12s. I plan on upgrading the suspension and the gears to probably 3.73s. I just want a really fun car that will take lots of 4th gens and 5th gens off the line. I am going to be rebuilding the transmission and adding a shift kit and ratchet shifter.
I don't want my car to just sound good, I want her to perform and take any car that gives me trouble at lights and such.
theshackle
Mar 5, 2017 06:37 PM
