305 to 327, 91 camaro
Car: 91 Camaro RS
Engine: 305 TBI
Ive got a late 60's 327 available to me, now i don't know awhole lot about these motors but can i put it into my 91 camaro? Can i use the TBI from the 305 that i got? Any info would be great.
Car: 92 Camaro RS
Engine: 305 TBI
Re: 305 to 327, 91 camaro
It should work, TBI could be tuned for a mild 327 but the TBI intake won't bolt on due to the center two intake bolts are different, biggest problem is I think early 327's did not have mounting holes in the cylinder heads, not sure about the later ones, so you would not be able to use the factory serpentine accessory belt drive. Oil dipstick is on the other side of the engine too. I would sell the 327 and buy a late 350, would be much easier.
Car: 1990
Axle/Gears: stock
a long while back someone told me that you could elongate the holes and bolt it together. like a dummy i thought he was talking about the head, who wants to screw with the head. today i was thinking about it, because i need some cheap heads to bolt my 90 tpi to and it finally dawned on me. he wasn't the fool, i was. he was not talking about the heads, he was talking about the intake manifold. take it to a shop and have them elongate the interior 4 holes on intake manifold, then it will fit at 90 degrees and you can use those to turn the hole into 90. it was so simple but i missed it completely.
i agree that he should use the modern 350 though.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
327 heads don't have the hardened exhaust valve seats necessary for unleaded gas.
Most people do 350's. I'm doing a 327 and about to swap it into my 88 305 tbi. Don't let anyone give you a hard time on the 327 - it's a good engine. However you will be spending just as much if not more than doing the same type of work to a 350.
A few things I have learned.
1. As stated, heads of 60's vintage don't have the hardened exhaust seats. Also as stated, some don't have the front accessory mounting holes for the serpentine stuff. But if you are thinking of aftermarket or newer heads anyway, then no problem.
2. You will need a special flywheel to get the 2 piece rear main seal block (probably 168 tooth flywheel) to fit the 700r4 torque converter. One is currently on the way from summit to me. The bolt circle to mount the converter is different.
3. Depending on the year, there may be a vent draft tube connection at the block near the distributor tube. Cars now have pcv system instead of this "road breather. The block hole for the draft tube can be plugged with a freeze plug.
Car: 91 Camaro RS
Engine: 305 TBI
awsome, great to hear, yea i don't plan on sticking with the heads that are on it. Cause i want to either do TBI or TPI
Just noticed you are in California. I don't know anything about the emission laws there except to be very afraid. The 327 or other old engine swaps might not make your state authorities very happy.
Suggest you look into it before proceeding.
Transmission: 4L80E/4L80E
You don't need to use a 168-tooth flexplate. '82-'85 3rd gen f-bodies used a 153-tooth 2-piece RMS flexplate.
With later heads, the 327 will look exactly like a '91 engine except for the dipstick. Doubt that will raise suspecion. Keep the cam reasonable and all of the emissions equipment with a proper EFI system, you won't have any problems.
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
OMG don't ruin the 327 with TBI heads!
Those things like to rev and TBI heads can't do that. good set of vortec heads and some mild porting will do you fine with a good after market intake and TBI adapter plate or one of the TBI manifolds.
Turbo 327 was one of my thoughts for my car but it would cast to much to build right, and thats an engine you wouldn't want to cut corners on.
five7kid, this is where I was told to use a 168 tooth flywheel and the reason I ordered one. (once I realized my original 1967 flywheel didn't have the right bolt circle for the torque converter)
https://www.thirdgen.org/forums/engi...ine-setup.html
Maybe that advice advice was for 1967 blocks only?
Venom204, what exact year is your 327?
Car: 91 Camaro RS
Engine: 305 TBI
Ok so i was looking up the block number and its "3970010" So it shows it as the 69-79 350 but also shows it as the 68 year 327. Can anyone shed some light on what it might be?
'68 & '69 327's used the large journal cranks, like the 350. The block could have been manufactured in '68. Or, it may actually be a 350. Only way to know is to check the crank.
Car: 91 Camaro RS
Engine: 305 TBI
KK i dunno if it still has the crank my father in law is going to look for it, its in peices, he says the heads are there as for the pistons and the crank hes gotta look for it. Hes got an identical 350 that a guy let the water freeze in it and popped the freeze plugs but it also cracked the block need to the freeze plug
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
