umm... 2 right side heads????
Old Mar 22, 2009 | 08:07 PM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
Ok so here is my question... I pulled heads off my dad's 1973 chevy c10 truck... that used to be on his 1978 Camaro... with screw in studs... pretty good heads for my app...
Seems i have to right side heads though...
The one on the left needs to have a hole where my finger is... but the other side looks like the one on the right... but you flip the one on the right over and it looks like the one on the left...
Question: Do you think its possible to have it tapped or am i better off buying a new set of heads...?
Old Mar 22, 2009 | 08:14 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: umm... 2 right side heads????
Originally Posted by 92RSStud
Do you think its possible to have it tapped?
A credible machine shop will have that tapped for you in minutes....
Old Mar 22, 2009 | 08:53 PM
92RSStud's Avatar
Engine: 355CI
it wont ounch into a water jacket or anything?
I assummed it would be ok but just making sure.
Old Mar 22, 2009 | 09:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Every SBC has two right side heads.
Also has two left side heads.
They're the same heads. Compare them with the same ends showing, they will have the same type ends.
Yes, you should get new heads. A simple set of Vortecs will be highly superior to anything the factory put out in 1978.
Old Mar 22, 2009 | 10:53 PM
92RSStud's Avatar
Engine: 355CI
not using vortec heads... already have everything for the motor...
done feel like using self-aligning rocker arms... not shelling out $650-2000 for heads... if i have working heads.
then another 150 for rocker arms.
Already have everything purchased to put the motor togeter... i realized that yes the heads can be left or right.. but was more or less wondering if you can buy new "old" style heads with the holes casted into them or should i just have a machine shop tap me a hole..and will it be ok? like no tap into a water jacket.. or anything.
Old Mar 23, 2009 | 12:47 AM
five7kid's Avatar
Not a problem. As long as they don't drill too deep.
84z96L31vortec
Aug 20, 2017 12:16 AM
wruiz
Aug 11, 2015 02:59 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
