Right Engine For My Swap
Car: 1988 Pontiac Trans Am
Engine: 305 soon to be LS series
I am seeking personal experience suggestions on to what engines the community feels is the right one to put into a third gen. I currently have a 305 TPI in my 88 Trans Am and I am looking to swap out the strong but tired engine. I am looking at dropping in a LS1, 383, or maybe a 454. I am looking to run it on pump gas, and still pull out between 350-400hp or so. I am seeking the advice of all you third gens out there who have a made a swap for advice and knowledge.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: Right Engine For My Swap
what is the goal? street perf.? drag race. or combination of both.
a swap is not too complicated. a sbc with some strong vortec heads or better will be the easiest way with a carb and auto trans and will be the quickest esp. if u use a th350.
power will consume more fuel and mpg will suffer. if its dd, can u tolerate a 300-400-500 hp fuel bill? etc.
I would like to get 350-400 hp running a pump gas, meaning I want it for a daily driver, street not looking to drag race. Yes I can tolerate the fuel bill that comes with the amount of hp I am looking at. It doesn't get great mileage in the first place. The car is an automatic also.
Transmission: 4L80E/4L80E
An LS1 will put out that kind of power and still get MPG in the 20's when you aren't feeling the need to use the power.
