92 Engine swap alternator mounting issue
Old Apr 9, 2009 | 07:41 AM
camaro922k3's Avatar
Car: 1992 Camaro RS
Engine: 5.4
Hi, I have a little problem with my engine swap over the winter I swapped out my 305 small block for a rebuilt 67 small block engine runs great. However the one problem I have is my alternator will not fit its a CS style bolt holes are setup fot 10-3 mounting that cars mounts are for 12-6 I do not want to cut in a alternator with external voltage regulor.. Does anyone know if you can get a mount for the CS style alternator that will fit a 67 small block keep in mind there is no accessory holes in the head b/c its a 67, this is quite hard for me.. I might end up have to make something but I would rather buy something... any input would be apricated.. thanks
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
