Question about motor mounts for V8 swap.
Old Apr 14, 2009 | 05:25 PM
richterbelmont2's Avatar
So, I decided to swap out the old 2.6L V6 engine from my 1985 Camaro with a 350 Small Block. My question is, what kind of motor mounts do I need to mount it on the Camaro? Are V6 motor mounts different from the 350? What do I have to do to mount it in there? And also, is there a certain crossmember or mount that I need for the tranny? I have a 350 tranny as well.
Old Apr 14, 2009 | 06:21 PM
toomany's Avatar
Re: Question about motor mounts for V8 swap.
https://www.thirdgen.org/forums/engi...swap-read.html
Most of the info you need is there.
A Th350 will work. You will need a new driveshaft though, unless you are using a long (9"?) tailshaft model.
Old Apr 15, 2009 | 06:16 PM
poomwah's Avatar
sorry for hijacking... would you also need to change driveshafts if switching from a stock 350 with 700r4 to a chevy 350 with th350 trans?
Old Apr 15, 2009 | 10:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, unless the TH350 is a 9" tailshaft version.
$750 L98
Feb 1, 2025 02:25 PM
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
86White_T/A305
Sep 21, 2015 05:28 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
