305 to 307 swap
Old Apr 21, 2009 | 11:30 AM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
305 to 307 swap
I came across a really good deal on a high output 307. It makes about 330 horsepower and has 10 compression. My 305 is very old and worn out do you think this would be a good swap. Would I have trouble finding headers for it or attaching it to a 700r4. My car is an 87 z28. I know i will at least need a flex plate to make it attach to the two piece rear main seal.
Old Apr 21, 2009 | 05:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since all 307's from the factory were base V8's with 2 bbl carbs, in order for it to be "high output", it would have to completely redone - heads, cam, etc.
Heads are the wild card - really need to know which ones it has on it.
Flexplate is a piece of cake - '83-'85 f-body V8 replacement unit.
The dipstick will be on the driver's side - but, 3rd gen headers solves that problem.
Other than that, no issues, depending upon what heads are actually on it.
Old Apr 21, 2009 | 05:44 PM
nascarfan7's Avatar
Car: 1991 Z28
Engine: 5.7
Re: 305 to 307 swap
This is a Chevrolet 307, correct? Installing it into an F-body shouldn't present any issues.
Now if it's an Olds 307...You might run into some issues
Old Apr 21, 2009 | 05:45 PM
five7kid's Avatar
I keep forgetting that.
Good catch.
Old Apr 22, 2009 | 06:32 AM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
Re: 305 to 307 swap
Yes it has been completely rebuilt with lots of high end parts. The guy was building it for someone then they decided they didn't want it anymore and now the builder still has it.
So would 305/350 style headers such as hooker 2055s fit a 307?
Old Apr 22, 2009 | 01:35 PM
five7kid's Avatar
If it is a small block Chevy (not the Olds), and has standard exhaust port heads, yes, the 2055HKR would fit it just fine.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
