clearence issues
Car: 86 Firebird
Engine: 355 vortec heads
Transmission: 700r4 Huges 2500 stall
Axle/Gears: 4:10
clearence issues
I hope this is the right spot to post this if not I am sorry. I just finished swapping out a 305 in my 86 firebird to a 355 with vortec heads and an edelbrock performer rpm intake. Now I am having trouble finding an air cleaner that will allow me to shut my factory hood. Has anyone else had this issue and could you give me some advice on where to get one or pics of any mods you have done to make it work. I have a powerbulge hood and I like the looks of it and don't want to switch hoods. Thanks for any help.
Transmission: 4L80E/4L80E
A drop base air cleaner usually does the trick, unless you have a spacer under the carb.
Car: 86 Firebird
Axle/Gears: 4:10
Re: clearence issues
I have tried a 14" drop base with no luck. It was two large. So I tried a 9" one but it didn't have a drop base. Still no luck. So today I bought the Edelbrock triangle one. I haven't tried it yet. All the parts store here only have the 14" with a drop base. What size did you use and where did you find it. Again this is a 86 bird so the front drops of sharper than a camaro.
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i had a cheap 14 inch.before and now i have a edelbrock 14, i am using a edelbrock carb , if using a holley you may have to dent the bottom a little more. i will try to get pics
