v6 cc to v8 non cc swap
Old Apr 25, 2009 | 09:31 AM
nut/sticky89rs's Avatar
Car: 89 RS Camaro
Engine: 5.7-10:1 compression vortec
Transmission: World Class T5
Axle/Gears: 373 Disc Brake Posi
father son 89 rs v6 2.8 to 350 v-tech non cc swap. Engine's built need info on how to wire up non cc distributor. I saw a thread on this a while back but can't find it now, anyone got any info???
Old Apr 25, 2009 | 02:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The pink wire that originally went to the coil is the switched ignition power. There should also be a white wire for the tach.
What kind of distributor are you using?
Old Apr 25, 2009 | 03:50 PM
Car: 89 RS Camaro
Re: v6 cc to v8 non cc swap
thanks for the info.distributor is factory hei from 78 350 with summit street/strip upgrade.
Old Apr 25, 2009 | 03:56 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
IIRC, you should just be able to connect those to the terminals on the HEI coil. Tach goes on the connector the rear of the car and Battery goes to the connector towards the front of the car on the coil.
Old Apr 25, 2009 | 03:59 PM
Car: 89 RS Camaro
sorry not much on the computer. thanks for the input
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
