Will it work?
Old Apr 26, 2009 | 06:05 PM
jboyd91's Avatar
Car: 91 Camaro z28
Engine: 350 5.7
Will it work?
I was looking at doing an engine swap in my 91 camaro. It currently has a t-5 transmission and i was wondering if i would be able to bolt it up to 93 lt1 engine. Also if i need to buy any parts to make it work.Thanks for the help
Old Apr 26, 2009 | 06:32 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Will it work?
You can, you'll need to put your '92 flywheel on the LT1, so you can use your clutch and pressure plate. The '93 LT1 used a larger flywheel, with a different pressure plate pattern for the "pull-off" clutch. But it's a straightforward swap.
Old Aug 24, 2009 | 05:59 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Will it work?
Would it work if he used an LT1 flywheel and LT1 pressure plate w/ the T5 from the '92?
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
