swap goes bad
Old May 17, 2009 | 10:11 AM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
swap goes bad
ok long story short i puled the motor about a year ago and now im puting in a 350 from 74 iv got everthing pritty much under control but a few little things
1 cant find the five blots that bolt up the block to the trans were can i buy these.
2 Im trying the buy a Dorman Air Conditioner Eliminator
but also can find the three blots for that eather
3 i also need a flexplate but idk if i should buy it for my car (90 iroc 305)
or the engin ( 74 csb 350 out of idk )
sorry its more then one thing but i got to figure out these three problms in less then a week =/ sorry all
Old May 17, 2009 | 10:32 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: swap goes bad
try summit and then try using the search button on the top of the page in the red line.
Old May 17, 2009 | 11:45 AM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Re: swap goes bad
IDK about the first two items, but the flexplate I do know. You need an 153 tooth flex from 85 back. The larger flex will not fit bellhousing( like from a truck). New ones can be found any parts store or used are pretty abundant.
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
Bryan F
Aug 18, 2015 02:28 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
