intake swaps
Transmission: 4L80E/4L80E
Not directly. The center two intake mount bolts on each side are at a different angle than the rest in '87-up engines, while the '86 engines had all of the bolts at the same angle.
You can modify the intake bolt holes so they fit the other type of heads.
Elongating the holes. It could also be argued that the bolt hole face should be angled as well.
ambainb
Apr 25, 2016 09:21 PM
