engine swap
Old Jun 29, 2009 | 06:07 PM
jtmoney01's Avatar
engine swap
Hey i have a 89 camaro rs. It has a 305tbi motor. I was wondering if i were to swap to this motor
http://www.summitracing.com/parts/MLL-BP3830CTC1
It has a manual fuel pump. what would i need to do to make this work as far as fuel delivery? Any help would be greatly appreciated.
Old Jun 29, 2009 | 10:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the record, that isn't emissions-legal in any of the 50 states for use on public roads.
As to what you need to do, it's basically an EFI to carb conversion with an engine swap thrown in.
What transmission do you have or will you be using?
Old Jul 1, 2009 | 04:44 PM
jtmoney01's Avatar
Re: engine swap
Im going to be using a 700r4 from monster transmissions.
Old Jul 1, 2009 | 05:58 PM
five7kid's Avatar
You'll need a throttle valve cable corrector bracket for the carb throttle arm, and some means of locking up the torque converter clutch during cruise conditions.
I guess I didn't address your original question. Personally, I'd remove and block off the mechanical pump and use the in-tank electric with a return-style regulator.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
