305 to 350 Motor Mount Question
Old Jul 13, 2009 | 08:21 AM
haxmire's Avatar
Car: 1987 350 swap
I am dropping in a crate 350 because my 305 blew up, anyways, I was wondering if the motor mounts go in the same exact way as the 305. Should it be turned towards the front to use the mount towards the back of the car or the one towards the front of the car.
Here is a pic of what I mean (sorry if you can't tell, cell phone)
Question is should the bottom bolt be using the one I am now, or the other one for the 350? I would assume it is the same but you know I don't want to just continue onwards with them and find out it was the other way considering how much of a pain these are to do.
Thanks.
Old Jul 13, 2009 | 01:24 PM
haxmire's Avatar
Car: 1987 350 swap
Re: 305 to 350 Motor Mount Question
Bump, anyone know?
Old Jul 13, 2009 | 02:50 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
the motor mounts are the same for a 305 or a 350, the clamshells that go on the motor, however, are left and right make sure you put them on the same sides that they came off of.
Old Jul 13, 2009 | 02:54 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
That's how I bolted my mounts in when I swapped from the V6 to the 350. Everything lines up just like it used to.
Old Jul 13, 2009 | 03:02 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Crate engines don't come with mounts, just reuse the 305 stuff as it was with the 305.
jhawkeye
May 25, 2022 06:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
