anyone know of a slim air cleaner that will work
Old Jul 10, 2009 | 12:43 PM
supersport92's Avatar
Car: 1992 RS camaro
Engine: chevy 350
Axle/Gears: 3.73 axle
i just swapped a 350 into my 92 camaro RS and i need an air cleaner that will clear the hood with an edelbrook intake and a holley carb with an adapter plate. check out the picture, i only have like 2 inches of clearance.
Attached Thumbnails anyone know of a slim air cleaner that will work-0709091145.jpg
Old Jul 10, 2009 | 03:17 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: anyone know of a slim air cleaner that will work
If that's a regular Performer, not a Performer RPM, then you can use most any dropped-base 14x3" air cleaner.
Old Jul 10, 2009 | 03:38 PM
Car: 1992 RS camaro
Engine: chevy 350
this might kind of sound of novice but how can i tell if its a performer rpm or just a performer
Old Jul 10, 2009 | 03:40 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
regular performer says edelbrock at the front, down between the water neck and the front intake runners, and performer at the rear. rpm says edelbrock performer rpm at the front atop the front runners.
Old Jul 10, 2009 | 04:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Even with a Performer, will the adapter cause an issue?
JamesC
Old Jul 11, 2009 | 10:01 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The OP doesn't need any adapter for anything related to this. Either intake will accept that carb without any adapter, and no need for any adapter between the carb and the air cleaner.
Old Jul 11, 2009 | 02:02 PM
JamesC's Avatar
My point was that the adapter would take up space.
JamesC
Old Jul 11, 2009 | 03:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
JamesC, what adapter are you referring to? There is no adapter involved in this thread.
Old Jul 11, 2009 | 03:25 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
P.S. Yes, the OP mentioned one, but did you miss where I told the OP it's not needed?
Old Jul 11, 2009 | 05:54 PM
JamesC's Avatar
I understand that the adapter's unneeded, but if the OP wishes to keep it, will there be a problem?
JamesC
Old Jul 11, 2009 | 10:16 PM
Car: 1992 RS camaro
Engine: chevy 350
i believe james might be talking about the carb adapter to the intake, that adapter make the top of my carb come pretty close to the top off the hood, i was asking if anyone new of an air cleaner that will work. im possitive someone has the same setup as me, its a pretty common one
Old Jul 13, 2009 | 03:08 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
remove the adapter. Unless it's a nitrous plate, it belongs in the trash.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
