400 flexplate issue
Old Jul 22, 2009 | 05:32 PM
Tallpaul's Avatar
400 flexplate issue
When swapping a 400 SBC in place of the 350 in an 89 T/A, what flexplate needs to be used? If I run the 400 flexplate (168 tooth) will I have starter clearance problems with headers?
Thanks,
Old Jul 22, 2009 | 09:01 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: 400 flexplate issue
you will have to run an externally ballanced flexplate on the 400 don,t know if the 163 will be to big for the headers but your starter will also have to match the flexplate
Old Jul 23, 2009 | 07:49 AM
chesterfield's Avatar
Car: Pontiac
get one of these and use your 153 tooth flexplate
http://www.speedwaymotors.com/Chevy-...ates,3262.html
Old Jul 23, 2009 | 11:51 AM
Tallpaul's Avatar
Thanks, I have seen those. Do you have any experience using one?
Old Jul 23, 2009 | 09:10 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
That is pretty neat wish I would have known about them a few months back. Wonder how well they work?
Old Jul 24, 2009 | 08:50 AM
Car: Pontiac
No, but I plan to if my project ever moves forward. just need a few more things like pistons and a car to put it in.
Old Jul 25, 2009 | 05:09 AM
Tallpaul's Avatar
Thanks Chesterfield, I talked to the machine shop operator he said they can balance a 350 flexplate to match the 400. I am leaning in that direction.
Thanks again,
Old Jul 31, 2009 | 09:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
When I did my 400 swap, I stuck with the stock replacement starter and flexplate for a 78 C10 w/ the 400 sbc stock. I did have an issue with clearance on my hedman headers, but nothing a couple whacks with a mini-sledge and a remote solenoid couldn't fix
Old Aug 1, 2009 | 07:07 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
The balance plates work flawlessly,as long as you torque your flexplate properly.
If it were me,I'd go with a stock 400 flexplate,and run an entry level ministarter.You can get them for $120-$150,and they don't have to work near as hard to spin your engine over.
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
greenyone
Sep 2, 2015 03:39 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
